I’ve been using Deluge with Sonarr for months and it recently stopped working. I had been using SSL, but even if I turn off SSL it doesn’t work.
With SSL Off I get a “Verify SSL settings” error
With SSL on I get “Unable to connect through SSL”.
The problem may in fact be with Deluge. I upgraded it tonight to the latest build with no effect. The webui works from any web browser, but without SSL.
I’m using this intranet only so I don’t need SSL at this point.
Well I updated it and it did not help. I may have to delete and start over… or maybe I’ll switch to something else altogether (I don’t love Deluge as it is although it works).
Did you recreate the certificate for it? Old versions of Deluge created less secure certificates, but generating one with the new version of deluge should fix it.
Well I have discovered that I’m too stupid to create a cert on Windows. After a day wasted on this I’m done. Most of the examples are Linux so I’m snookered here. the actual Windows example on the Deluge site doesn’t work with the version of OpenSSL I used (and using a 7 year old version seems idiotic to me).
Even complete removal of all Deluge files doesn’t remove the old Deluge configuration so I can’t reset that either.
I won’t use uTorrent and Deluge is pretty much on my shitlist (never warmed up to it). Is there another native torrent client (for Sonarr) to try that works in Windows?
I really don’;t care is I use SSL either… if Deluge would just work without it I’d be fine. It’s only used on my LAN.
The cert is valid, but generated in a way that is now considered deprecated.
My understanding is Deluge will create it automatically if it doesn’t exist, which based on a forum post it might be stored here: %APPDATA%\deluge\ssl\
Or you can generate one (though security wise it’s less than the recommended standard and Chrome will likely start rejecting them in 2017): http://www.selfsignedcertificate.com/
I agree using a version that old is idiotic.
Transmission QT works, it’s lightweight, but it doesn’t have real category support which I find a bit annoying, otherwise no complaints, there is also Qbittorrent.
What error do you get when you try to avoid using SSL to connect to deluge?
