Sonarr version (exact version): 2.0.0.4230 Mono version (if Sonarr is not running on Windows): n/a OS: Windows 7 ((Debug logs)) (posted to hastebin or similar): Description of issue:
Hello everyone, I have recently setup Sonarr and Deluge on my home server using this guide https://www.cuttingcords.com/home/ultimate-server/torrents-and-deluge and initially everything worked very well. A couple of days later now and I’m finding that my completed torrents in Deluge are not being extracted as was initially setup. I have checked the settings multiple times in Deluge and even tried to uninstall/reinstall with the same results. I’m really at a loss here and can’t troubleshoot this issue and was hoping someone could help me?
Also, is there a way to trigger the Extractor on completed torrents again? I’m having to manually extract/copy to my Drone Factory folder as a result of the Extractor plug-in not working in Deluge.
Oh my god am I frustrated. I figured out what was going on as I have Sonarr running on a separate system than Deluge and I had to do remote path mappings. I was also using Drone Factory which I really didn’t need.
Now I’m having a problem that I can’t change the Drone Factory folder! Sonarr looks like it changes it but then a couple of minutes later it is set back where I don’t want it to be and it is messing up my downloads! Someone please help!
I finally got it. The biggest issue was not having the remote path mappings setup correctly. I was trying to use the server name but ended up trying the IP address and it worked. The settings not saving issue was very weird but I fixed that but not running Sonarr as a service and just running it locally. I think it had to do with file permissions. I like Sonarr better not running as a service as not I can see the icon running in the tray.
