From an old thread on this topic in January. Sorry for the repeat, but…
markus101Team Sonarr Jan '16:
If the setting is still set then it didn’t forget about it. Was the episode still monitored?
When the file is detected as deleted by Sonarr it is ignored, if its remonitored for whatever reason then that setting is irrelevant
Markus, I hope you see this, but I do not understand this answer. I believe, like many others, that this behavior is wrong or not properly working. I have many monitored series because they are still showing, but need to delete the previous seasons (or episodes) because they are watched or I need space. Yet, they are constantly being downloaded again and replaced again and again. I delete, it comes back. The setting for ignore deleted is set to on.
Maybe we need a Monitor New Episodes setting, that only cues new releases? I am not sure how that might work other than Sonarr knowning which release is current. Even better, EACH SEASON should have it’s own “Ignore Deleted” or “ignore old” setting. There are some monitored series that I want old, while others I only want the current or new. I really would like it to stop adding old episodes that I have deleted or are just old and I don’t care about to the queue. (Or is there a way to tell Sabnzbd to queue on pause mode, so I can choose to get it or not?)
Thanks for a great program. Fix this, and I will be off the the donate button for sure.
If the setting is enabled and Sonarr previously saw the episode in the series folder, upon disk rescan it will unmonitor it.
If Sonarr never saw the episode on disk or the setting was not enabled when Sonarr detected it was missing then it won’t unmonitor it.
You can use Season Pass to tell Sonarr to only monitor future episodes (from the point in time it’s executed). A setting to only monitor future episodes wouldn’t work because they’d be ignored as soon as they completed airing.
Why? You have the option when adding the series to tell Sonarr which episodes to monitor, All, Future, Missing, etc (same options on Season Pass).
Sure, set the Older priority to Paused in Sonarr’s SAB settings.
Ah, got it. It was a level deeper than I realized. It was set to on, so that is good. Thanks.
BUT…
OK, older items set to paused. Settings on everything set to "monitored only."
In EVERY series I have, I have unchecked the monitor “tab” (the little flag is not black) on all the old seasons.
I have ignore on deleted items turned on.
Today, all of season 9 was sitting paused in SABNZBD. Yesterday, it downloaded seasons 5 and 6 again, after I deleted them all a few days before when they downloaded. .
Yes, I did check that. The little flags were all white. That was the first thing I checked. But I will try your idea here and see if that makes it better. Thanks.
