OS: Windows 10
Debug logs: Can be provided.
Description of issue: I seem to have a delay in post processing that’s a little annoying when I’m trying to bulk fill some old episodes. Basically there is a one minute delay between the scan starting and the return status coming back as completed. Every episode gets a log like this:
[07:57:02] [DEBUG]::NZBDRONE: Scan started with id: 1440232
[07:58:02] [DEBUG]::NZBDRONE: The Scan command return status: completed
It’s always almost exactly 1 minute. Not a huge deal under typical use but when I’m backfilling a hundred episodes it adds up quickly.
Anyone know why this might be happening? Is it expected behavior? For what it’s worth I’ve looked at other logs around the internet and seen that delay much lower, closer to 20 seconds.
