Debug and trace logging not working in 2.0.0.1319
Hi,
I’m running 2.0.0.1319 and when i enable trace or debug, i still only get info in the logs. Both logs within nzbdrone and output from running nabdrone.exe in foreground.
If i change the logging to trace and save, it seems to save OK but doesn’t take affect.
Is there something else i should be doing ?
thanks
It only affects the log files, not the log database at this time. Which are on checking?
ok, within nzbdrone i go to “System, Logs and under Table” where i only see Info alerts. No debug or trace. Same thing for stdout from .exe when run in foreground… only Info.
I don’t know what you mean by log database, is there somewhere else i can check for logging? I guess this is a known issue ?
Thanks.
That’s the log database (shown under table in the UI), click on files to a view debug and trace logging.
