The.Walking.Dead.S04E13.720p.WEB-DL.AAC2.0.H.264-Cyphanix
For instance results into : The Walking Dead - S04E13 - WEBDL-720p-DRONE
Replacing it with DRONE, even though Cyphanix is the release group.
The release group parsing is all the same, which is pulled from the filename when importing. I just added a test to our test suite to confirm that it does parse properly and it does.
What was the full path that was imported? You can see that in History by clicking the ‘i’ on the right side next to the import event. You’ll see something similar to: https://db.tt/OLvcKZqN
Hmm will watch it again on new download, i already wiped the db for another bug.
Which bug was that? Unlikely that you’d need to wipe the DB at all.
Sorry wrong description, meant that I wiped the logs(db). Opened another thread for the other bug.
U may close this one.
I was referring to history, which is not in logs, but part of the main DB. Let us know if you see his come pick again.
