Cutoff/quality questions
Have just transferred all from sick over to here. Loving the program so far. Had a question on quality and cutoff. Currently have all my shows using the 1080p setting. When will drone look for better quality? Does it do on own automatically? Basically say it grabbed the webdl version I watched it and all is good I do not really need the HDTV version since episode is watched. Or some shows if I’m inpatient I’ll manually grab a 720 version and watch. I’m not going to want to rewatch at 1080. Hopefully my question makes sense. Thanks
Let me know if you have questions after reading: https://github.com/NzbDrone/NzbDrone/wiki/Quality-Profiles it should answer you question, but the short answer is, it will keep grabbing files of better quality until the cutoff is met.
