Environment Notes:
- Synology DS414 w/ DSM
5.2-5644 Update 1
- Sonarr Ver.
2.0.0.3645
– grabbedv20150731-8
from the SynoCommunity package index, used Sonarr’s self-updater to update to2.0.0.3645
I tried to set up the Slack notification script, detailed here. After specifying the path to the script, clicking “Test” in the Custom Script edit modal yields “Test Successful”. Strangely though, Sonarr doesn’t seem to be doing anything. Nothing shows up in the logs, but according to CustomScriptService.cs
, it should be writing a debug message: "Executing external script: slack.sh"
. I let Sonarr download a file to see if the Test button was broken, but again no dice.
I ssh’d into my Synology box and switched to the nzbdrone user with su nzbdrone
. As the nzbdrone user, I was able to execute the script just fine, which should hopefully rule out any permissions issues.
Next, to see if Sonarr was doing anything at all, I made a test script called foo.sh
. It does the following:
touch /sonarr-scripts/bar
I pointed Sonarr at it, clicked “Test”, and no bar
file appeared. Like before, directly executing the command through the CLI as the nzbdrone user works just fine.
So that’s where I’m at – I’m kind of at a loss right now. If you guys have any ideas, I would love to hear them.
