I have a few scripts that I need to add on download/upgrade. However, the order is important. Am I correct in assuming the order they show up on the connect page is the order they are executed?
There is no guarantee of them executing in that order, it’s likely they will at this time though (as long as they are returned from the DB in a consistent order).
That was the next thing I was going to check. But they should be in the same order every time, correct?
Like I said no guarantee, but probably by ID.
