I reencode some of my series from WEB-DL 720p to SD quality to save space.
Right now I have a batch script running every hour that checks specific folders for .mkv files. If it finds any, they are copied to a working dir, reencoded to SD .avi and copied back to where they came from. This works quite well, but it would be convenient to add the batch to certain series.
Also, since I set WEB-DL 720p as desired format, I have to keep the avi files named “SXXEXX - Episode Name WEB-DL 720p” to prevent nzbdrone from replacing them.
Older, unwatched Seasons are named DVD at the end.
How about adding the ability to run custom scripts for certain shows, and being able to flag them as “not to be replaced” even though tags dont meet the desired quality?!
