I just thought I would check in and find out if you had found anything, or anybody else, with this problem. Actually it still doesn’t seem to be hurting anything, or causing any other problems, but again, I thought I would check.
When I click on one of the displayed error lines I get:
Message
Couldn’t download media cover for [280706][Younger]: HttpCurl method HEAD not supported
Exception
System.NotSupportedException: HttpCurl method HEAD not supported
at NzbDrone.Common.Http.Dispatchers.CurlHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) <0x4183abb0 + 0x004b3> in :0
at NzbDrone.Common.Http.Dispatchers.FallbackHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) <0x416c9ca0 + 0x00213> in :0
at NzbDrone.Common.Http.HttpClient.ExecuteRequest (NzbDrone.Common.Http.HttpRequest request) <0x416c70d0 + 0x00177> in :0
at NzbDrone.Common.Http.HttpClient.Execute (NzbDrone.Common.Http.HttpRequest request) <0x416c6c70 + 0x00027> in :0
at NzbDrone.Common.Http.HttpClient.Head (NzbDrone.Common.Http.HttpRequest request) <0x4191a5b0 + 0x0002b> in :0
at NzbDrone.Core.MediaCover.CoverAlreadyExistsSpecification.AlreadyExists (System.String url, System.String path) <0x4191a460 + 0x0009c> in :0
at NzbDrone.Core.MediaCover.MediaCoverService.EnsureCovers (NzbDrone.Core.Tv.Series series) <0x4191a0d0 + 0x00155> in :0
I just tried to install mono-devel and got back:
Depends: libmono-cecil-private-cil (<4.2.1.103) but 4.2.3.4-0xamarin2 is to be installed
Depends: mono-mcs but it is not going to be installed
Depends: mono-gac (=4.2.1.102+dfsg2-7ubuntu4) but 4.2.3.4-0xamarin2 is to be installed
Depends: mono-xbuild but it is not going to be installed
Depends: libmono-cil-dev (=4.2.1.102+dfsg2-7ubuntu4) but 4.2.3.4-0xamarin2 is to be installed
Depends: libmono-2.0-dev but it is not going to be installed
Recommends: mono-csharp-shell but it is not going to be installed
This should have been easy but was not. The problem is that its asking for versions that are not available. There is also one called mono complete that adds a pile of stuff. I have come to the conclusion that I should just shut up and live with it. Its not causing harm and that is enough.
Thanks for all the help we tried and I am a happy camper.
