Hi, just moved to drone from the beard. I like this much better for sure.
I had a question about NZB Factory. I’m sure the most standard format for storing all your shows is something like X:\Shows\ShowName\Season #\Episode.s01e02.mp4 . When I disable sorting in SAB and setup NZB Factory, it doesn’t seem to do anything. It just moved the episode and it’s long folder name to E:\TV Shows\Ugly.Name.s02e04.rlsgrp\ugly.file.s02e04.mp4
Howcome it is not placing them in their respective season folders and renaming the shows?
Also, I think it would be really beneficial to be able to modify the order of quality of episode searched first. I, for one, have a 250GB monthly download limit. I would prefer to download at the lowest quality (SD is nice) and if no SDs can be found, then at that point I am fine downloading a 720p version.
Thanks
Thats SAB doing to the sorting, you want the drone factory folder to be the same place SAB drops off tv shows, but make sure they’re not sorted TV shows. Then drone will pick them up and move them.
Example:
Drone Factory/SAB TV category both point to C:\\Unsorted TV
Sorted TV shows are in: C:\\TV
More info: https://github.com/NzbDrone/NzbDrone/wiki/Sorting-and-Renaming
As for qualities, you can re-order them however you want if you have advanced settings visible: https://github.com/NzbDrone/NzbDrone/wiki/Quality-Profiles
Hey - Yeah after posting, I realized I had the TV Show category set to E:\TV Shows and not the Drone folder. Sab was just throwing them in TV Shows and unsorting them.
NZB Factory is working well now.
I honestly did not see any way to re-arrange them even with the Advanced stuff enabled. But I think I know what to do using the bars and whatever.
Anyway thanks for the reply, appreciate it. good work with Drone.
