Sonarr version 2.0.0.4949: Mono version 5.4.0.201: Linux 4.10.0-37-generic #41~16.04.1-Ubuntu: https://pastebin.com/HtTukKzP
Sonarr is not grabbing Conan (Conan (2010) - to be exact). My indexer is returning results, but there is an error. Not sure what this error means. I have no issues with other daily tv shows (a la Kimmel) which have the same attributes. I suspect it’s the (2010) part that’s causing issues
Please post the ((debug logs)) that include processing this release (not just the error message from the logs table).
Based on just the error it looks like there are multiple episodes with the same release date, so Sonarr has no way of knowing which one would be correct, so it throws an error.
This has to be a series name/date problem. I searched for Season 7, Ep 139 with Billy Eichner which aired 10/04/2017. However, it appears to be searching for 04/10/2017 Conan with Jenna Elfman.
That’s a different problem, it looks like your indexer is returning the wrong results, Sonarr is making the correct request, but getting results with reversed day/month.
I don’t see the error you reported initially in the logs you posted though.
I just tried sending directly to the indexer and it returned ‘Conan.2017.04.10.Jenna.Elfman.HDTV.x264-CROOKS English’ again. NZBHydra is disabled. So guess it’s an indexer issue.
So - got some help from the indexer and it turns out they use fuzzy search and it returns the closest thing to what I asked for. It appears in this case the actual episode I want isnt available so it’s returning something it thinks is close. Only it’s not what I want so sonarr appears to (rightfully) reject. Guess the answer is the episodes just arent available.
