I added and searched for a whole series. This is what Sonarr found:
15-12-19 20:33:23.1|Info|NzbSearchService|Searching 6 indexers for [XXXXX : S01]
15-12-19 20:33:31.7|Info|DownloadDecisionMaker|Processing 146 releases
15-12-19 20:33:35.5|Info|DownloadService|Report sent to Deluge. XXXXX Season 1-3 S01-S03 UNCUT COMPLETE SERIES 1080p BluRay XXXXXXX
I was running out of space on my hard drive so Sonarr had a problem importing:
15-12-24 01:33:34.0|Warn|ImportApprovedEpisodes|Couldn’t import episode P:\Ultimate_Server\DL_Torrents_Dups\XXXXX Season 1-3 S01-S03 COMPLETE SERIES 1080p BluRay XXXXXXX\XXXXX Season 2 S02 UNCUT 1080p XXXXXXX\XXXXX.S02E01.UNCUT.1080p.XXXXXXX.mkv
System.IO.IOException: There is not enough space on the disk.
at System.IO.File.InternalCopy(String sourceFileName, String destFileName, Boolean overwrite, Boolean checkHost)
at System.IO.File.Copy(String sourceFileName, String destFileName, Boolean overwrite)
at NzbDrone.Common.Disk.DiskProviderBase.CopyFile(String source, String destination, Boolean overwrite) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Disk\DiskProviderBase.cs:line 191
at NzbDrone.Common.Disk.DiskTransferService.TryCopyFileVerified(String sourcePath, String targetPath, Int64 originalSize) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Disk\DiskTransferService.cs:line 433
at NzbDrone.Common.Disk.DiskTransferService.TransferFile(String sourcePath, String targetPath, TransferMode mode, Boolean overwrite, Boolean verified) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Disk\DiskTransferService.cs:line 181
at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.TransferFile(EpisodeFile episodeFile, Series series, List1 episodes, String destinationFilePath, TransferMode mode) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:line 118 at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.CopyEpisodeFile(EpisodeFile episodeFile, LocalEpisode localEpisode) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:line 96 at NzbDrone.Core.MediaFiles.UpgradeMediaFileService.UpgradeEpisodeFile(EpisodeFile episodeFile, LocalEpisode localEpisode, Boolean copyOnly) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\UpgradeMediaFileService.cs:line 60 at NzbDrone.Core.MediaFiles.EpisodeImport.ImportApprovedEpisodes.Import(List
1 decisions, Boolean newDownload, DownloadClientItem downloadClientItem) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeImport\ImportApprovedEpisodes.cs:line 90
BTW, why does it show drive m:\ in the log? Where is that?
I cleared space on my hard hard drive and checked the series; Only S02E01 was missing,.so I tried to search for this episode but nothing was available:
15-12-26 01:33:34.0|Info|NzbSearchService|Searching 7 indexers for [XXXXX : S02E01]
15-12-26 01:33:42.6|Info|DownloadDecisionMaker|Processing 77 releases
15-12-26 01:33:44.1|Info|EpisodeSearchService|Episode search completed. 0 reports downloaded.
So I tried to search for the whole season instead, but still nothing available:
15-12-26 01:42:10.4|Info|NzbSearchService|Searching 7 indexers for [XXXXX : S02]
15-12-26 01:42:19.6|Info|DownloadDecisionMaker|Processing 121 releases
15-12-26 01:42:22.6|Info|SeasonSearchService|Season search completed. 0 reports downloaded.
Finally, I tried to search for the whole series (again), but still nothing found:
15-12-26 10:33:14.1|Info|NzbSearchService|Searching 7 indexers for [Luther : S01]
15-12-26 10:33:22.7|Info|DownloadDecisionMaker|Processing 146 releases
15-12-26 10:33:27.8|Info|NzbSearchService|Searching 7 indexers for [Luther : S02]
15-12-26 10:33:36.4|Info|DownloadDecisionMaker|Processing 121 releases
15-12-26 10:33:39.7|Info|NzbSearchService|Searching 7 indexers for [Luther : S03]
15-12-26 10:33:48.1|Info|DownloadDecisionMaker|Processing 115 releases
15-12-26 10:33:51.7|Info|NzbSearchService|Searching 7 indexers for [Luther : S04]
15-12-26 10:34:00.9|Info|DownloadDecisionMaker|Processing 136 releases
15-12-26 10:34:05.2|Info|SeriesSearchService|Series search completed. 0 reports downloaded.
That is strange, it had just found and downloaded the whole series (but import failed). Why didn’t it find something now? Are already downloaded Torrents somehow “Blacklisted” (it is not in the Blacklist)?
How can I fix this? Do I need to delete all 4 seasons from disk and start over in order to get the missing S02E01 episode?
