OS:
Do a Google search. There’s examples on how to get both setup. I moved away from SAB and went with NZBGet instead. It’s been a while since I last use SAB. Whatever the case, get SAB working, all the settings as you think they need to be, then get Sonarr working and configured. No matter what, you’re going to have a few hickup’s along the way as you learn how to use each program. This is where looking in the logs for both can really help figure out what’s not working correctly. Once it’s all running there’s not much you need to worry about after. You could spend hours to a week getting it working how it should. It look me a while to get Sonarr working as it should on my ReadyNAS 516 as my experience with Linux isn’t much. Required a lot of Googling to figure things out. Even though I had been running it for some time on my Windows computer. It’s a learning experience.
