Could not create SSL/TLS secure channel
[warn] IPTorrents: IPTorrents https://iptorrents.com/torrents/rss?u=hidden;tp=hidden;download The request was aborted: Could not create SSL/TLS secure channel.
What happens here exactly?
Sonarr can’t make an SSL connection so it fails, if you’re on Windows it may work if .net 4.5 is installed, on other systems running mono, it may work if it can fallback to curl (once released).
Why does it fail? and how do we fix it? I’m using win10 so net 4.5 is already present. when it fails, does it try again? and do this mean that stuff aint getting downloaded? :stuck_out_tongue_closed_eyes:
Could fail for a number of reasons, typically its RSS ciphers not supported by .net, but could be a misconfiguration on their end. Do you get the error every time?
It does not try again (it would try again on the next RSS sync) and it means nothing would be grabbed from that site if the connection fails over and over.
