Spaldo
August 7, 2016, 3:51am
1
Sonarr version (exact version) : 2.0.0.4230
Mono version (if Sonarr is not running on Windows) : 4.2.2 - Synology
OS : Windows 10
Description of issue :
I would like to copy the Sonarr backup files:
/usr/local/nzbdrone/var/.config/NzbDrone/Backups/scheduled
On a regular basis. Unfortunately I have been unable to do this as the folder is in the system area and only the root user in SSH. I have tried a symbolic link, however, in the shared folder I cannot access it.
Has anyone done this? or have any ideas?
Do you have access to root? If so, you might be able to do a cron job rsync/etc.
Spaldo
August 8, 2016, 4:02am
3
Yep, I do. I finally worked out a way to do it on Synology.
For those who also want/need to keep a copy of the backup files, here is how I did it:
Create a batch/sh file with the following command:
yes | cp -rf /usr/local/nzbdrone/var/.config/NzbDrone/Backups/scheduled/* /volume2/Backup/Sonarr
or using rsync:
rsync -avh /usr/local/nzbdrone/var/.config/NzbDrone/Backups/scheduled/ /volume2/Backup/Sonarr/
Saved that file as “copy-script”
Then added the following line to the crontab:
00 12 * * 1 root copy-script
This runs the copy script every week on Monday at midday. You can change the frequency by changing the numbers in the crontab line.
I am not too familiar with rsync, so I used cp instead. So far it looks like it is working.
rsync is a great product because it only copies changed files. If you wanted to look into it, it might be called something else on Synology but same tech.
Spaldo
August 9, 2016, 1:12am
5
Alright, I will try rsync (it is included in Synology). For those reading this in the future, this is the command I used:
system
Closed
October 8, 2016, 1:12am
6
