Hi - I have read many posts, the wiki, the noob guide, etc. As the title says, I am migrating from a Sickbeard/SABnzbd/XBMC setup to Sonarr/SABnzbd/XBMC.
I use XBMC via Apple TV for front end and my TV Shows are stored on a NAS. The NAS is a networked drive, but it is also has a static IP. From the forum, I think I would access it like this? “\LS-QL1A9\share\TV Shows” and this is specified when adding a series?
Currently, SABnzbd uses Temporary Download Folder: “SABnzbd\incomplete”, Completed Download Folder: “SABnzbd\complete” and Watched Folder: “SABnzbd\NZB”. I have category “TV” setup in SAB and Sonarr, so I have set the Drone Factory Folder to “\SABnzbd\complete\TV” - my understanding is that Sonarr will monitor that folder and automatically post-process the file when SAB adds content?
I am trying to understand if I need to rename folders and shows in my existing library so that Sonarr will recognize them as downloaded (hopefully not). My folders and filenames are different mainly in that the Series Title does not have the date “(XXXX)” in the Series Folder Name or in the Episode file name. Do I have to add the dates, or will Sonarr be able to recognize the existing files? If I have to rename folders and files I will have to also rebuild my XBMC library, which is time consuming - not to mention the actual renaming of dozens of folders and hundreds of files!!
Hopefully, that will get me up and running. Thanks in advance for any assistance!!!
