Connection to OZnzb fails
I see this issue has come up before, but despite trying different URL´s I am still not connecting to OZnzb.
Anyone?
You’ve hit your API request limit for the day. Sonarr requires 96 API calls a day for RSS syncs running every 15 minutes + at least one per search (depending on how many results are available).
Thanks. Sorry, I´m very new to this. So, obviously the allowed 5 API calls a day aren´t going to be sufficient ? But doesn´t my status on OZnzb indicate that I should be able to connect - https://www.dropbox.com/s/d492jpy99zy5ckl/Screenshot%202015-02-15%2005.16.09.png?dl=0
Are you using the correct API key? Its also possible that the site isn’t updated to reflect the actual number of calls.
But 5 is nowhere near enough if RSS is enabled for it, but might be okay for searching only.
Yes, re-generated a new API to make sure. I have tried adding OZnzb to Sonarr several times within the last few hours. The same issue persists. Despite not being able to connect my API calls are used up… .
Sonarr will use one API call when adding an indexer (to verify its been setup properly), but a 429 error shouldn’t prevent it from being added (if I recall correctly).
Working now after a moderator reset my API calls. Thanks for your time and patience :slight_smile:
