Connection to backend lost problem
ubuntu 16.03.3
Version 2.0.0.5054
Mono Version 4.2.3
sonarr.debug.txt: https://pastebin.com/qLTR0TPW
I have started to get “connection to backend lost”. When this happens sonarr has stopped and I have to restart it to get it going again. This happened to me a while back but there have been new versions since then so I thought I had better ask your thoughts before I start working on it. I have also noticed something a bit strange in that I get this error every 15 minutes whilst doing absolutely nothing.
I have also had some problems with my net connection and this might be the problem as my net is currently working and I haven’t had the problem so the 15 minute thing no longer is pertinent and there is a very good chance that this is all about my internet connection and nothing to do with sonarr. Its all a mystery so I will keep an eye on it. I also noticd that I had to restart sabnzbplus too. I will post this and, if it happens again I will pay more attention and amend it.
If Sonarr is crashing due to mono crashing you’ll need to check the standard output and error (redirect it to a file to capture it), ((trace logs)) will give more information on what Sonarr was doing leading up to the crash.
Version 2.0.0.5054
Mono Version 4.2.3
sonarr.debug.txt https://pastebin.com/pEKfdK4s
sonarr.txt https://pastebin.com/hfvEXGXb
My connection to backend lost problem has not returned so; I should have paid more attention and figured it out. My fault as my net connection was hinky and the problem has gone away.
I now am getting a pile of errors involving “HttpCurl method HEAD not supported”. I am not sure that this means anything as everything seems to be working just fine so I thought I would send you the basic logs for your information.
Thank you for your help and I apologize - I should have waited to make sure it wasn’t what it was
Looks like a problem with libcurl.
Since it doesn’t seem to be giving me problems I will assume that if anybody else has the same problem it will get updated and then, when you update …
