Connect sonarr to a remote VPS running transmission
Hi, unfortunatelly the forums didnt give me an answer to this question …
I am running transmission daemon on a VPS, filling out the sonarr connection tab with transmission settings results in an error : Unknown exception: Remote site redirected to http://IP:port/transmission/rpc = it is redirecting me to the webui.
My question is : Is it even possible/supported to get an connection outside of the localhost or am I doing something wrong ?
Or is it that to be able to use this option only the daemon (without the webui) would be running ?
Thanks
Yes its possible to connect to remote connections.
Hastebin the logs from the connection test and we can take a look.
here you go : http://hastebin.com/aqowolekek.tex
i stripped the IP,PORT and username from the logs
anyway i think this is the issue :
15-6-3 02:18:21.8|Debug|TransmissionProxy|Url: http://HOST_IP:PORT/HOST_IP:PORT/transmission/rpc GetSessionId
accourding to the help “?” the url base should be a prefix in this format : http://[host]:port/[urlBase]/transmission/rpc
If im not mistaking it should be empty in my case, but i am probably wrong :slight_smile: Tested other possibilities : http,IP,domain name - same results.
OK I have figured it out.
the rpc url of the daemon has to have the default value “/transmission/”
Everything else fails with the error message mentioned above.
Anyway, thx, have to say,love sonarr so far (my 1st day :slight_smile: )
cheers
