Conan - TV Show, Help Renaming
“Conan” (talk show) is showing up as “Conan the Barbarian” TV show as soon as it downloads in Sonarr and Plex catches it. Is there any way to fix this? Sonarr is showing it as Conan the Talk Show, but Plex is not.
Thank you :slight_smile:
Not really anything we can do. The scene insists on naming it Conan which is the exact same title as Conan the Barbarian is listed on TheTVDB as.
If the folder on disk is named Conan then Plex will have problems.
Rename your Conan folder to Conan (194751) and Plex will get it right!
Thanks! I’ll give that a shot.
Also - all of my talk shows seem to be getting both the HDTV downloads (180MB) and 720p downloads (800MB) simultaneously. NZBget is showing the HDTV download first and then the 720p download, all directed from Sonarr. It’s not all the time, but most of the time.
Any idea how to fix this?
Thanks!
Depends, whats the cutoff for your profile set to?
If its 720p then Sonarr will grab the SDTV release first then the 720p release when its available (assuming they both aren’t available at the same time).
Thanks Markus!
Greatly appreciated :slight_smile:
