Mono version (if Sonarr is not running on Windows): N/A
OS: Windows 10 Pro 64bit
Debug logs (posted to hastebin or similar):
http://hastebin.com/xegehikige.1c
I only noticed this this morning, all my queued itemsf rom the previous day were showing up as not available, but i checked SABNZBDs history and they had all downloaded without issue and were sitting in the completed downloads folder. I went in and manually moved them all and did a manual scan.
I then ran some tests with some backlog episodes i haven’t downloaded but could use to see what was happening. So i queued an episode up through the manual search feature in Sonarr. Everything was working as expeceted, nzb was queued in sabnzbd, sonarr was tracking the download completion fine. Then sabnzbd completes the download and sonarr gets to a 100%, and then the episode just says “episode missing from disk”. Doesn’t show that it failed or anything. I go look in the completed downloads folder and the completed download is there.
I enabled the drone factory and that pulled in the episodes without issue, so there can’t be a permissions issue on the completed download folder. To further make sure this couldn’t be an issue I created a new set of completed downloads folders and update sabnzbd to use the new folders, making sure that the security on those folders gave everyone full control (not the most secure, but no way that a permission could be causing this issue).
I thought it might be a sabnzbd issue, since that just updated to v1.0.0, but that can’t be right either since the download tracking is working, and the files are being placed in the correct download folder, so it can’t be something there.
i restarted sonarr, and manually queued up an episode of Last Week Tonight with John Oliver S01E06 for testing purposes. While this downloaded Sonarr ran an rss sync, which i removed fromt he above log because hastebin complained that the document was too long. The log above represents everything else in the log from when sonarr restart to when i queued up the episode and to when it was finished downloading. The finished file is inside my completed downloads folder but is not being imported. Sonarr shows that episode as being missing from the disk, but does not list the download as failed or completed nor imported. So there is something seriously awry.
Hoping someone can advise on why this is happening.
Thanks
