Completed Download Handling Help Please
Hello all
I have been using Sonarr (Nzbdrone) for a long time now with no problems.
I use NzbGet and Drone Factory to download my files, but would like to try
Completed Download Handling, but can’t figure out what needs to be changed
in Sonarr and NzbGet. Is there a screen shot tutorial that shows the changes
that need to be made to Sonarr and NzbGet somewhere to make this work or
somebody that could take screen shots of their setup windows and Pastebin
them for me?
Sonarr ver 2.0.0.2180 - Oct 31 2014 Installed
NZBGet 12.0
Any help would be appreciated
Thank You
Assuming get and Sonarr are on the same machine:
###In Sonnar###
  1. Shown advanced settings (by the save button)
  2. Change the path for the drone factory folder (in Sonarr) to something else, for example: C:\Completed\Drone Factory
  3. Change the interval for Drone Factory (you don’t need it running every minute)
  4. Enable completed download handling
You don’t need to make any changes in nzbget.
Hello markus101
I have changed my settings so look like yours
and when I try to save it I get an error on the screen
app.js: 18313
Object expected
I have an image of my screen but can’t Pastbin it to you
Try refreshing the page and changing the settings again. I’ll have to take a look and see where that error is coming from.
Hi there here is a screen shot of my setup
markus101 have you looked to find out what the error app.js: 18313 is?
Which OS is Sonarr running on?
If Linux/OS X, which version on mono?
Client side:
Which browser?
Which OS is it running on?
Sonarr and NzbGet on same drive
Win 8.1
IE 11
Thought it might be something with IE 11, but its not. Could you try clearing your cookies and other browsing history and trying again? Does Chrome or Firefox work?
What download client are you using? I see you’ve setup Blackhole as your client, instead of SAB or get, you’re not going to see much of an improvement in that case.
