Sonarr version 2.0.0.4472: Mono version4.2.3: Ubuntu 14.04: ((Debug logs)): http://pastebin.com/u338yQ2N transmission version 2.92
Hello, i try to use sonarr with tranmission, my episode are correctly added but at the end of the download, the episodes are not copying (no hard link).
17-1-3 20:33:15.2|Debug|DownloadedEpisodesImportService|Bones.S11E22.FiNAL.FRENCH.720p.HDTV.x264-SH0W folder quality: HDTV-720p v1
17-1-3 20:33:15.2|Debug|DiskScanService|Scanning '/home/admin/dl/SeriesAutoDl/Bones.S11E22.FiNAL.FRENCH.720p.HDTV.x264-SH0W' for video files
17-1-3 20:33:15.2|Debug|DiskScanService|0 video files were found in /home/admin/dl/SeriesAutoDl/Bones.S11E22.FiNAL.FRENCH.720p.HDTV.x264-SH0W
That looks like a permissions problem, make sure the user running Sonarr has access to that folder.
17-1-3 20:33:15.2|Debug|Parser|Parsing string 'Mr.Robot.S01.PROPER.VOSTFR.WEB-DL.x264-ARK01'
17-1-3 20:33:15.2|Debug|Parser|Episode Parsed. Mr Robot - Season 01
17-1-3 20:33:15.2|Debug|Parser|Language parsed: French
17-1-3 20:33:15.2|Debug|QualityParser|Trying to parse quality for Mr.Robot.S01.PROPER.VOSTFR.WEB-DL.x264-ARK01
17-1-3 20:33:15.2|Debug|Parser|Quality parsed: WEBDL-480p v2
17-1-3 20:33:15.2|Debug|Parser|Release Group parsed: ARK01
17-1-3 20:33:15.2|Debug|DownloadedEpisodesImportService|Unknown Series Mr.Robot.S01.PROPER.VOSTFR.WEB-DL.x264-ARK01
Looks like that series isn’t in Sonarr so it can’t import it.
thx for your reply, il try to set all permission (777), i clear my directories and i enable “Create empty series folders”. but the folder do not create. i think that the problem it’s same.
I found for Serie folder, if the basic folder is empty sonarr no create the serie folder (WTF!!!)
but for my initial problem i don’t know.
i try to use Drone Factory Options and it’s work perfectly, the video is move. (i don’t want use Drone factory for seed raison)
But Completed Download Handling doesn’t work, no copy no hard link juste nothing.
the download stay inside the activity menu with message
“Bones.S11E22.FiNAL.FRENCH.720p.HDTV.x264-SH0W Intermediate Download path inside drone factory, Skipping.”
i disable drone factory because il don’t want to move the video but create the link (for save the seed)
if i enable drone factory my video is move correctly, i don’t understand why download handling doesn’t work.
ps : thanks markus101 for your help, i hope find an solution with you.
Anoher point i yse sonarr inside the container with multiple instance (i try to stop other, but no change), and eatch instance run with the specific user.
only admin user have the right to the sonarr directory (/opt/sonarr)
