Try a manual search for an episode to confirm everything is set up correctly. You should get a list with results, with one or more without a red exclamation mark. If all have a mark, hover over them to see why sonarr rejects that particular download. Adjust settings & repeat
check with manual search and click on âsend to download queueâ to see if your indexers are working.
Also you can post your âcalendarâ section of sonarr so to see what is going with the releases
Since you havenât specified any details of what Indexers youâre using, for instance, thereâs only a point up to which I can help, but from what I can see, 26x04 is the last aired episode of Chopped so far, and on Kickass Torrents, I see torrents all the way up to 26x04 (https://kat.cr/usearch/chopped/)
So if Kickass is one of your indexers, and your Sonarr is set up correctly, it should work.
Add Kickass to your indexers if its not, and do a Manual Search and see what happens.
iirc Chopped is one of those series thatâs truly messy when it comes to hdtv numbering, webdl numbering and tvdb numbering.
Youâre probably better off grabbing it all manually to make sure the wife gets the right episode at the right time
