Clean up after processing
I’ve set up sonar on pc. I download to QNAP.
Everything is working correctly. Series download, get renamed and go into proper folder.
However I can’t figure out how to get rid of all the unwanted files that come with download. sfv, sff sample etc.
I’m also left with unpack folder which is probably something to do with sabnzbd.
Any help appreciated on how to automatically delete these files and folders.
As long as Sonarr imported all the video files (except for samples), it will remove the directory. If its not deleting it for all imports, please pastebin a debug log of the import so we can take a look.
Hi Markus
I’m not sure if these are correct logs. Same thing happened. Downloaded, renamed and moved but unwanted files left.
15-3-19 21:41:41.7|Info|NzbSearchService|Searching 2 indexers for [The Shield : S04E11]
15-3-19 21:41:42.3|Info|DownloadDecisionMaker|Processing 3 reports
15-3-19 21:41:43.0|Info|Sabnzbd|Adding report [The.Shield.S04E11.A.Thousand.Deaths.iNTERNAL.DVDRip.x264-GORE] to the queue.
15-3-19 21:41:44.1|Info|DownloadService|Report sent to download client. The.Shield.S04E11.A.Thousand.Deaths.iNTERNAL.DVDRip.x264-GORE
15-3-19 21:41:44.1|Info|EpisodeSearchService|Episode search completed. 1 reports downloaded.
15-3-19 21:41:49.3|Error|ImportDecisionMaker|Couldn’t import file. Y:\Downloads\The.Shield.S04E10.Back.in.the.Hole.iNTERNAL.DVDRip.x264-GORE
Unable to parse file on import: [\NAS\Multimedia\Downloads\The.Shield.S04E11.A.Thousand.Deaths.iNTERNAL.DVDRip.x264-GORE\sample-ts4x11-gore.mkv]
We need debug logs and please pastebin them.
Hi Lusset,
You can block the unwanted extensions in SABnzbd.
Goto Config, Switches and there you can list the unwanted extensions in the Queue section.
Hi rvank,
The only option for unwanted extensions are off, pause or abort.
After the tv show has been downloaded. It’s moved into the correct TV series folder.
In my downloads folder there is still the folder from the TV show. It has sample, srs, info, sfv, srr files.
Is there an option on sonarr to automatically delete that unwanted folder?
