Clarification of postprocessing issue
Hello, I’m in the process of switching to Sonarr from SickRage. I wanted to test Sonarr out, so I paused a few active shows in SickRage, and set Sonarr up to monitor them. Sonarr downloaded an episode, and then nothing happened. I did some reading on the Sonarr wiki, and it sounds like Sonarr and the torrent app (Deluge in my case) need to be running on the same computer. Right now Deluge runs on an Ubuntu VM running on my Windows 7 computer, Sonarr runs straight on that Windows 7 computer. Am I correct that I should install Sonarr on my Ubuntu VM to get postprocessing to work?
They can be on separate machines, but you will need to mount a share to the VM so Sonarr can import the files and setup a Remote Path Mapping. The queue in Sonarr and logs should indicate that its unable to access the path/use it because its for another OS.
Thanks! Remote mapping worked.
