CHD issues on v2.0.0.4562
Sonarr version (exact version): v2.0.0.4562
Mono version (if Sonarr is not running on Windows): 3.10.0 (mono-3.10.0-branch/ce003f4 Tue Nov 25 20:18:29 UTC 2014)
OS: Raspbian Jessie
v2.0.0.4472 debug log: http://pastebin.com/raw/w3EJ9cRm
v2.0.0.4562 debug log: http://pastebin.com/raw/xGke9ner
Related settings page screen: http://imgur.com/yjg5gdv
Sonarr works great on latest master build (4472) but I just wanted to go with develop versions. I constantly having DownloadedEpisodesImportService on the version. I tried many ways to get over with the issue including creating a symbolic link exactly identical to my remote path, with this trick Sonarr saw the files that should be imported but Sonarr failed again. I have attached the debug logs of two versions.
I’ve reverted version back to v4472, and I didn’t even change any single settings. And CHD now works flawlessly again.
What has changed between the two versions to make Sonarr fail on unix based devices?
By the way, Radarr the fork of Sonarr has the same issue.
Not a native speaker, sorry for any language mistakes.
17-2-2 18:53:59.6|Error|DownloadedEpisodesImportService|Import failed, path does not exist or is not accessible by Sonarr: /tmp/mnt/Seagate_Backup_Plus_Drive/DL/Downloaded/Its Always Sunny in Philadelphia S08E02 HDTV x264-2HD[ettv]
Based on your screenshot you have a Remote Path Mapping setup that doesn’t appear to be working. IS the Host field correct (it needs to match the Host field in the download client exactly).
I don’t recall any recent changes to remote path mappings or the import process that would explain this beyond the remote path mapping being wrong, but the logs from v2.0.0.4472 don’t show any importing of that file either.
Well, It is working with uncorrect Host settings but I have set it to the ip address of host as I set on download client. Hope I did it right. http://imgur.com/a/wmsaA
Sorry for the wrong debug log; here is the right one which you can see failed and successful imports.
http://pastebin.com/raw/zDLHTxYq
