Changing DEFAULT root path
I screwed up when first setting up sonarr… I set the default path to a specific TV series - FearTheWalkingDead (ftwd). Now, when I add a new series, it adds it as a folder UNDER the FTWD folder… and of course plex can’t find it.
I know in can use series editor to mass change the root path, but I want to change the default so that when I add a new series, it defaults to …/tv/ instead of …/tv/ftwd/
I’m happy to edit files if needed… just need the pointers. I don’t want to reinstall and setup as I finally have it working really well and don’t want to mess it up!
Suggestions welcome.
Remove the wrong path from the Import Existing Series dialog (same place it was added), as soon as you use a different root folder it will become the default.
