Changing AppData folder location
Is there a way to change the directory all the metadata and banners are being downloaded to? If possible I’d like a sickbeard type setup where all the banners and stuff are being saves to the series folders.
Enable XBMC metadata, Sonarr stores images for its own use in its own AppData folder.
Yes, I have enabled the metadata download, however I do not want it to download the data to it’s AppData folder. I’m running Sonarr off of my SSD so those are taking up space, and I would rather have them downloaded to either the series folders themselves or another folder of my choice. At this point, this is the only thing holding me back from switching from SickBeard.
Something like that would involve moving the entire AppData folder: https://trello.com/c/zSThQAv6/456-portable-mode-change-appdata-location
You also have the option to symlink it somewhere else.
Guess I’m sticking with sickbeard for a while longer, then. Thanks anyway.
