Change quality assigment
All of my files are in mp4 format with varying qualities and what I have read is that mp4 is associated with SDTV.
So NzbDrone wants to re-download my entire collection.
I would like the ability to to assign containers to different qualities.
Added to Trello, but its still better to include the quality of the episode in the filename because you’ll only be able to change the default and .mp4 could be HDTV 720p or Bluray 1080p
how about the option to manually change a downloaded shows quality, like in sick beard. I have some 480p videos that are detected as 720p because they are mkv container, so it would be awesome to be able to tell drone that the shows i downloaded are actually sdtv.
also, just out of curiosity, does mediainfo have the ability to detect resolution? that could also be used to get the required spec, and some way of updating the currently downloaded shows would be great to manually fix incorrect matches.
@PhAzE you can change it on a per episode basis by clicking the quality of the episode in the episode details modal, for a full season this is in the back log: https://trello.com/c/75MOaJ92/397-change-parsed-quality-for-entire-season
Yes media info does, using it already is on Trello: https://trello.com/c/QlPTGYrN/352-use-mediainfo-to-extract-resolution-to-determine-quality-before-falling-back-to-extension
Oh OK I didn’t know you could change them per episode already. Awesome
