Change execution interval of 'Check For Finished Download' task
Currently it seems the task ‘Check For Finished Download’ is set to a 1 minute interval (perhaps the default?), however I don’t want it checking that frequently.
Is it possible to change this interval value somewhere? I’ve looked through all of the settings and there doesn’t appear to be anywhere obvious in the GUI
Thanks
It can’t be changed and we have no plans to make it configurable.
Why do you want it to be customizable?
