I’ve just started using Sonarr having come from sickrage and I’m liking it so fare apart from a couple of things, that will start making my files messy.
I have a lot of existing files that are all in lower case and I don’t like to rename the files. I would therefore find it useful to have a feature to change the cases on files (either by rename or not) to title format or lower case.
I’m not 100% what you’re looking for here, changing the case implies you’re doing some sort of rename, could you elaborate?
{series title} would make the series title lower case. {original title} should make the original release name lowercase and {Original Title} would leave it unaltered.
Ohhh, sorry… I should have posted a question first in another section.
I wasn’t aware this was something in the advanced section, I thought it was all templated. Therefore, I’m going to investigate this further. I’m betting I can do this already…
