Certain Downloads not processing
Good Evening.
Apologies if this has been covered previously. Im new to Sonarr and havent found a particular answer.
My set up is:
Freenas 9.3
SABnzbd 0.7.20
Sonaar info
Version2.0.0.3004
Mono Version3.10.0 (tarball Mon Jan 26 02:53:37 UTC 2015)
AppData directory/var/db/sonarr
Startup directory/usr/pbi/sonarr-amd64/share/sonarr/NzbDrone
Issue:
Certain series downloads not processing and transferring to series folder.
Background.
I have the setup working correctly as far as im concerned, most items requested either download, process and end up in correct program/series folder after popping it in the queue.
This suggests that, jails/permissions are correct.
However, this week, I requested a particular program, SAB received and downloaded 5 (early series) of the program, they were transferred into the shared download folder, at which point all activity stopped.
In Sab it showed the items as complete, when hovered over, it stated that ‘quick check’ was ok. But item all remained in the history list.
I looked in the download folder, all episodes were present and all were fully watchable.
I was told by a friend that if the naming wasnt correct ie. S01.E02 then it would fail, 1 out of 5 was like this, however the rest were either S01.E02 or S01E02.
Can anyone suggest some troubleshooting steps or is it just an occasional random issue.
Just for info, items before and after processed correctly, eve while they remained.
Many thanks
Nick
What does Sonarr show in Activity: Queue for these episodes?
What about debug logs?
Hi Markus,
Thanks for the reply.
I never even thought to check Sonarr (showing as not not disk now), Ive cleared log and re-requested all the files. Ill let it run and report back.
cheers
