I was changing to setup SSL in Sonarr and changed port 9898 in settings to 8989 so now when I try and start Sonarr it says that port is already in use. How can I fix this?
Cheers
Cheers
Here is the log
15-7-11 17:30:57.9|Info|Bootstrap|Starting Sonarr - C:\ProgramData\NzbDrone\bin\NzbDrone.exe - Version 2.0.0.3243
15-7-11 17:30:58.2|Debug|ProcessProvider|Found 0 processes with the name: NzbDrone.Console
15-7-11 17:30:58.2|Debug|ProcessProvider|Found 2 processes with the name: NzbDrone
15-7-11 17:30:58.2|Info|SingleInstancePolicy|1 instance(s) of Sonarr are running
15-7-11 17:30:58.2|Warn|SingleInstancePolicy|Another instance of Sonarr is already running.
15-7-11 17:30:58.2|Info|BrowserService|Starting default browser. http://localhost:8989
15-7-11 17:30:58.2|Info|ProcessProvider|Opening URL [http://localhost:8989]
15-7-11 17:30:58.4|Info|Bootstrap|Application is being terminated. Reason : Another instance is already running
15-7-11 17:31:50.9|Warn|Sabnzbd|Couldn’t get download queue. Unable to connect to SABnzbd, please check your settings
15-7-11 17:31:53.1|Error|Sabnzbd|Unable to connect to SABnzbd, please check your settings
I managed to fix it by deleting the config and log files.
Still can’t set up SSL and have done everything it says here https://github.com/Sonarr/Sonarr/wiki/SSL
