Can't save settings
Sonarr version (exact version): 2.0.0.4374
Mono version (if Sonarr is not running on Windows): 4.6.1
OS: Raspbian
((Debug logs)):
Description of issue: I’ve just set up sonarr and it mostly seems to be working. I can add series and trackers and a download client. However I can’t seem to save general setting like UI and media management. When I click the save button, there’s no confirmation pop up, and if I go to a different tab in sonarr and back to the settings, my changes have reset. If I check the logs, there is the following error.
Request Failed: Object reference not set to an instance of an object
System.NullReferenceException: Object reference not set to an instance of an object
  at NzbDrone.Core.Configuration.ConfigService.SaveConfigDictionary (System.Collections.Generic.Dictionary`2[TKey,TValue] configValues) [0x00032] in <a2def4a6d9e64792b741a24ccb4dcbec>:0
  at NzbDrone.Api.Config.NzbDroneConfigModule`1[TResource].SaveConfig (TResource resource) [0x00055] in <a143f823b36e4fc78dd5c66323c92b04>:0
  at NzbDrone.Api.REST.RestModule`1[TResource].<set_UpdateResource>b__44_0 (System.Object options) [0x0000e] in <a143f823b36e4fc78dd5c66323c92b04>:0
  at (wrapper dynamic-method) System.Object:CallSite.Target (System.Runtime.CompilerServices.Closure,System.Runtime.CompilerServices.CallSite,System.Func`2<object, object>,object)
  at Nancy.Routing.Route+<>c__DisplayClass4.<Wrap>b__3 (System.Object parameters, System.Threading.CancellationToken context) [0x00049] in <1d2d9d0dd65e4620a58118842d0cad7a>:0
I found someone here with the same issue who looks to have more better logs: https://www.reddit.com/r/sonarr/comments/5acirk/settings_unable_to_save/
Thanks
There is a fix for this in the develop branch and should be getting this released to the main release this weekend. Sorry for the issue!
