So my Windows 10 install got corrupted and I had to do a repair install. I’m in the process of reinstalling all my programs and setting them back up, but I’m having trouble restoring Sonarr. The Windows.old folder contains the files from the previous installation, but the only db files are “db-shm” files. Restoring those doesn’t work. Is there anything else I can do?
You need nzbdrone.db
either from a backup or Sonarr’s AppData folder (C:\ProgramData\NzbDrone), the db-shm
files are not sufficient.
