First, I apologize for asking this at all. I know similar questions have been asked dozens of times, but most of them seem to trail off without a real resolution, or the situation are different enough that I can’t connect the dots.
Here’s what I want to happen: I want Sonarr to watch for new episodes, then for Transmission to download them, and then for Plex to be able to play them. If someone can point me to a better guide for this, I’ll gladly take a look and try a different approach.
Here’s my current situation: I followed this guide to get set up. The directions are mostly fine, except that it provides no information on what Sonarr should be doing once it hands off a new download to Transmission. I think the guide assumes that I want my Plex library to be the same place that downloads end up, which I want to avoid.
Sonarr is getting episodes from RSS feeds. It passes them to Transmission, and they download successfully, but it can’t move them. My sonarr user is in the MediaUsers group, which has read/write access in the entire /Data Shared Folder.
When shows finish downloading, I get the error “Import failed, path does not exist or is not accessible by Sonarr: /Data/TV Shows/{show name}”. No matter what path I try, this happens. Here’s screenshots to show how I have things set up. Maybe someone can just tell me what needs to change.
Docker:
In my Transmission Docker environment, I also have these variables that might be relevant. I don’t think they’re relevant to Sonarr moving files, but Transmission seems to be behaving as expected.
TRANSMISSION_DOWNLOAD_DIR = /Data/Downloads/Torrents/Completed
TRANSMISSION_INCOMPLETE_DIR = /Data/Downloads/Torrents/InProgress
TRANSMISSION_WATCH_DIR = /Data/Downloads/Torrents/ToFetch
Download Client:
Remote Path Mappings:
I’m really not sure about remote path mappings, so I’ve been trying a bunch of things. As you can see from the Docker config screenshots, Sonarr and Transmission can access the same locations.
Can anybody point out where I’m going wrong here?
