I changed my path for The King of Queens (all seasons) and now I can’t get drone to load the page. I get the following error message:
[GET] Internal Server Error : /api/episodes?seriesId=139
Need server side logs, thats just the client side message. Turn on trace logging and try opening it.
trace logging is on since yesterday.
Just so that you know, I don’t have this issue with smaller series. I only get it with for example, Supernatural (9 series), Sons of Anarchy (6 series) etc…
Did you change your path for those shows as well? And how did you first run into this issue, just changed your path?
I understand what the issue is now, but anything you can provide to replicate the issue would be helpful. If you could also PM me a copy of your DB it should help my investigation.
I created this card to look into it further: https://trello.com/c/BCdN2mgl/248-if-episodes-and-episode-files-get-out-of-sync-you-can-t-go-to-series-details
I moved the folder from Y:\TV\The King of Queens to X:\TV4\The King of Queens and then I clicked on “Update series info and scan disk”.
Initially it loaded when I first went into it to do the refresh, once I did that the error started popping up. I ignored it and clicked on “Update series info and scan disk” and none of the seasons were visible.
Forgive my ignorance but where would I find the DB and what is the name of it.
Shedrock
Thanks for the steps, it should help reproduce it.
The DB is n C:\ProgramData\zbDrone the filename is nzbdrone.db
I pushed a fix that should correct the problem the next time your folders are rescanned, haven’t had a chance to reproduce the issue on my end yet though.
Awesome, thank you.
