Can't get torrents to work
Thanks to your help in another topic I’ve got my newsgroups working, but haven’t had any success with torrents yet.
I’ve added KickassTorrents as an indexer and it tests without error, then added uTorrent as a download client, which also tests without error.
Doing a manual search on a missing episode lists nzb files and torrents. If I click the download link for an nzb it works, but doing the same for a torrent does nothing, not even an entry in the activity list.
Did u set up web access for utorrent?
I did, but you pointed me in the right direction. I had set uTorrent Web UI options to use the guest account. Sonarr tested ok against it, but it doesn’t work in use. I changed it to the uTorrent admin account and set a password, now it works.
Thanks for your help.
