Just tried that and still no SSL working.
No it won’t make a difference.
Run the commands I mentioned earlier (with command prompt) and post the results to hastebin or take a screenshot of the output.
Did you add the new certificate that you generated for localhost
to your system as well as adding the thumbprint to Sonarr?
Yes I did.
