Can't establish a connection
running with ubuntu 16.04.4
the versions below are from reports below as I don’t know how to find info in files.
NzbDrone.exe - Version 2.0.0.5163
Mono version is 3.10 or better: 4.2.3
https://pastebin.com/EEcZFQ8D
The problem was:
Firefox can’t establish a connection to the server at localhost:8989.
I found this pretty strange so I thought I would report it. As far as I can tell
its all running now.
in system monitor, when highlighting mono I got:
/usr/bin/mono /opt/NzbDrone/NzbDrone.exe -nobrowser
Documententation of what I did follows explanation. I am sending you this as I thought you might be interested. As far as I know its working fine now. I have no idea what happened but the log might help in that.
I checked the status of sonarr.service and it seemed dandy (but wouldn’t connect).
I then ended mono and restarted it with "mono --debug /opt/NzbDrone/NzbDrone.exe"
then I did “systemctl start sonarr.service” as sonarr was inactive (didn’t display)
I then went back into firefox and tried to bring up localhost:8989 and, this time it worked.
below is what it all looked like:
greg@movies:~$ systemctl status sonarr.service
● sonarr.service - Sonarr Daemon
Loaded: loaded (/etc/systemd/system/sonarr.service; enabled; vendor preset: e
Active: active (running) since Sat 2018-04-07 09:10:11 PDT; 24min ago
Main PID: 16093 (mono)
CGroup: /system.slice/sonarr.service
└─16093 /usr/bin/mono /opt/NzbDrone/NzbDrone.exe -nobrowser
Apr 07 09:33:51 movies mono[16093]: [Debug] QualityParser: Trying to parse quali
Apr 07 09:33:51 movies mono[16093]: [Debug] Parser: Quality parsed: WEBDL-1080p
Apr 07 09:33:51 movies mono[16093]: [Debug] Parser: Release Group parsed: TBS
Apr 07 09:33:51 movies mono[16093]: [Debug] ParsingService: No matching series T
Apr 07 09:33:51 movies mono[16093]: [Debug] Parser: Parsing string 'The.Daily.Sh
Apr 07 09:33:51 movies mono[16093]: [Debug] Parser: Episode Parsed. The Daily Sh
Apr 07 09:33:51 movies mono[16093]: [Debug] Parser: Language parsed: English
lines 1-17/17 (END)
Thought I would throw this in for the heck of it.
config.xml
Debug8989*9898False405720321ea947068e5d9373e89f751aNoneTruemasterBuiltInTrue
STARTING:
greg@movies:~$ mono --debug /opt/NzbDrone/NzbDrone.exe
[Info] Bootstrap: Starting Sonarr - /opt/NzbDrone/NzbDrone.exe - Version 2.0.0.5163
[Debug] ProcessProvider: Found 0 processes with the name: NzbDrone.Console
[Debug] ProcessProvider: Found 1 processes with the name: NzbDrone
[Debug] ProcessProvider: - [17218] NzbDrone
[Debug] Router: Tray selected
[Info] MigrationLogger: *** Migrating data source=/home/greg/.config/NzbDrone/nzbdrone.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
[Debug] MigrationLogger: Took: 00:00:00.1641730
[Info] MigrationLogger: *** Migrating data source=/home/greg/.config/NzbDrone/logs.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
[Debug] MigrationLogger: Took: 00:00:00.0162267
[Debug] OwinAppFactory: Attaching NzbDroneVersionMiddleWare to host
[Debug] OwinAppFactory: Attaching SignalRMiddleWare to host
[Debug] OwinAppFactory: Attaching NancyMiddleWare to host
[Info] NancyBootstrapper: Starting Web Server
[Debug] BrowserService: non-interactive runtime. Won’t attempt to open browser.
[Debug] QualityDefinitionService: Setting up default quality config
[Debug] NotificationFactory: Initializing Providers. Count 20
[Debug] IndexerFactory: Initializing Providers. Count 12
[Debug] MetadataFactory: Initializing Providers. Count 4
[Debug] DownloadClientFactory: Initializing Providers. Count 15
[Debug] TransmissionProxy: Transmission authentication succeeded.
[Debug] SabnzbdProxy: Url: http://localhost:9100/api?mode=get_config&apikey=d2a1589f5f04d9e0b080657b365cf293&output=json
[Debug] IndexerFactory: Temporarily ignoring indexer newztown till 4/7/2018 9:59:23 AM due to recent failures.
[Debug] MonoVersionCheck: Mono version is 3.10 or better: 4.2.3
greg@movies:~$ systemctl start sonarr.service
THIS IS WHERE i WENT TO FIREFOX AND MADE SURE IT DISPLAYED.
THEN i CHECKED THE STATUS AGAIN FOR THE HECK OF IT
Active: active (running) since Sat 2018-04-07 09:59:54 PDT; 4s ago
Main PID: 17257 (mono)
└─17257 /usr/bin/mono /opt/NzbDrone/NzbDrone.exe -nobrowser
Apr 07 09:59:56 movies mono[17257]: [Debug] OwinAppFactory: Attaching NancyMiddl
Apr 07 09:59:56 movies mono[17257]: [Info] NancyBootstrapper: Starting Web Serve
Apr 07 09:59:57 movies mono[17257]: [Debug] QualityDefinitionService: Setting up
Apr 07 09:59:57 movies mono[17257]: [Debug] NotificationFactory: Initializing Pr
Apr 07 09:59:57 movies mono[17257]: [Debug] IndexerFactory: Initializing Provide
Apr 07 09:59:57 movies mono[17257]: [Debug] MetadataFactory: Initializing Provid
Apr 07 09:59:57 movies mono[17257]: [Debug] DownloadClientFactory: Initializing
Apr 07 09:59:57 movies mono[17257]: [Debug] TransmissionProxy: Transmission auth
Apr 07 09:59:58 movies mono[17257]: [Debug] SabnzbdProxy: Url: http://localhost:
Apr 07 09:59:58 movies mono[17257]: [Debug] MonoVersionCheck: Mono version is 3.
lines 1-17/17 (END)…skipping…
Have a nice day! No need to reply unless I have a problem of some sort.
I successfully added a connection to Newztown some while ago but recently it has been showing up as failed - just tested it again and the log in Sonarr shows this
HTTP Error - Res: [GET] http://newztown.co.za/api?t=caps&apikey=(removed) 404.NotFound
However when I put my api key in the URL and run in manually in a browser it connects OK
Here are the first few lines of the display
This XML file does not appear to have any style information associated with it. The document tree is shown below.
I have the same problem and noticed that when one tests its a crap shoot whether it is successful or failed. I can test it three times and one will be successful and another not, etc. Makes no sense…
Just realised some of the text in previous post is missing - here is the XML I get when I use the same URL that Sonarr claims gives it a 404 error
<?xml version="1.0" encoding="UTF-8"?>
<registration available="yes" open="no"/>
<searching>
    <search available="yes" supportedParams="q"/>
    <tv-search available="yes" supportedParams="q,rid,tvdbid,tvmazeid,season,ep"/>
    <movie-search available="yes" supportedParams="q,imdbid,genre"/>
</searching>
<categories>
<category id="1000" name="Console">
	<subcat id="1010" name="NDS"/>
	<subcat id="1080" name="PS3"/>
	<subcat id="1100" name="PS4"/>
	<subcat id="1020" name="PSP"/>
	<subcat id="1030" name="Wii"/>
	<subcat id="1060" name="WiiWare/VC"/>
	<subcat id="1070" name="XBOX 360 DLC"/>
	<subcat id="1040" name="Xbox"/>
	<subcat id="1050" name="Xbox 360"/>
	<subcat id="1090" name="Xbox One"/>
</category>
<category id="2000" name="Movies">
	<subcat id="2060" name="3D"/>
	<subcat id="2050" name="BluRay"/>
	<subcat id="2010" name="Foreign"/>
	<subcat id="2040" name="HD"/>
	<subcat id="2020" name="Other"/>
	<subcat id="2030" name="SD"/>
	<subcat id="2045" name="UHD"/>
</category>
<category id="3000" name="Audio">
	<subcat id="3030" name="Audiobook"/>
	<subcat id="3040" name="Lossless"/>
	<subcat id="3010" name="MP3"/>
	<subcat id="3020" name="Video"/>
</category>
<category id="4000" name="PC">
	<subcat id="4010" name="0day"/>
	<subcat id="4050" name="Games"/>
	<subcat id="4020" name="ISO"/>
	<subcat id="4030" name="Mac"/>
	<subcat id="4070" name="Mobile-Android"/>
	<subcat id="4040" name="Mobile-Other"/>
	<subcat id="4060" name="Mobile-iOS"/>
</category>
<category id="5000" name="TV">
	<subcat id="5070" name="Anime"/>
	<subcat id="5080" name="Documentary"/>
	<subcat id="5020" name="Foreign"/>
	<subcat id="5040" name="HD"/>
	<subcat id="5050" name="Other"/>
	<subcat id="5030" name="SD"/>
	<subcat id="5060" name="Sport"/>
	<subcat id="5045" name="UHD"/>
</category>
<category id="7000" name="Books">
	<subcat id="7030" name="Comics"/>
	<subcat id="7020" name="Ebook"/>
	<subcat id="7010" name="Mags"/>
</category>
<category id="8000" name="Other">
	<subcat id="8010" name="Misc"/>
</category>
<groups>
	<group id="188" name="alt.binaries.all-your-base-are-belong-to-us" lastupdate="Tue, 10 Apr 2018 20:32:44 +0200"/>
	<group id="138" name="alt.binaries.anime" description="This group contains mostly Anime Television." lastupdate="Sun, 08 Apr 2018 23:59:48 +0200"/>
	<group id="144" name="alt.binaries.anime.highspeed" lastupdate="Fri, 10 Nov 2017 18:57:32 +0200"/>
	<group id="159" name="alt.binaries.apps" lastupdate="Tue, 10 Apr 2018 14:20:18 +0200"/>
	<group id="187" name="alt.binaries.astronomy" description="New triballs" lastupdate="Tue, 10 Apr 2018 20:40:01 +0200"/>
	<group id="150" name="alt.binaries.blu-ray" lastupdate="Tue, 10 Apr 2018 21:25:14 +0200"/>
	<group id="171" name="alt.binaries.cats" lastupdate="Tue, 10 Apr 2018 20:32:25 +0200"/>
	<group id="40" name="alt.binaries.cd.image" description="This group contains PC-ISO." lastupdate="Tue, 10 Apr 2018 15:43:15 +0200"/>
	<group id="1" name="alt.binaries.cd.image.linux" description="This group contains Linux distributions." lastupdate="Sat, 07 Apr 2018 04:22:40 +0200"/>
	<group id="87" name="alt.binaries.cd.lossless" description="This group contains a variety of lossless Music." lastupdate="Fri, 10 Nov 2017 18:54:37 +0200"/>
	<group id="179" name="alt.binaries.chello" lastupdate="Tue, 10 Apr 2018 21:24:39 +0200"/>
	<group id="106" name="alt.binaries.classic.tv.shows" description="This group contains Classic TV and Movies." lastupdate="Mon, 09 Apr 2018 13:48:31 +0200"/>
	<group id="124" name="alt.binaries.comics.dcp" description="This group contains Comic Books" lastupdate="Tue, 10 Apr 2018 20:09:30 +0200"/>
	<group id="38" name="alt.binaries.console.ps3" description="This group contains PS3 Games." lastupdate="Tue, 10 Apr 2018 20:01:42 +0200"/>
	<group id="35" name="alt.binaries.cores" description="This group contains a variety including Nintendo DS. Lots of Foreign." lastupdate="Tue, 10 Apr 2018 21:24:15 +0200"/>
	<group id="36" name="alt.binaries.country.mp3" description="This group contains Country Music." lastupdate="Mon, 26 Feb 2018 20:22:43 +0200"/>
	<group id="199" name="alt.binaries.cybdolf" lastupdate="Sun, 16 Oct 2016 12:57:53 +0200"/>
	<group id="85" name="alt.binaries.dc" description="This group contains XVID and X264 Movies and TV. Mostly Foreign." lastupdate="Tue, 10 Apr 2018 21:24:07 +0200"/>
	<group id="86" name="alt.binaries.documentaries" description="This group contains Documentaries TV and Movies." lastupdate="Tue, 10 Apr 2018 10:17:24 +0200"/>
	<group id="160" name="alt.binaries.drummers" lastupdate="Mon, 18 Dec 2017 14:07:13 +0200"/>
	<group id="146" name="alt.binaries.dvd.anime" lastupdate="Sun, 11 Mar 2018 00:04:33 +0200"/>
	<group id="95" name="alt.binaries.dvd.movies" description="This group contains DVDR Movies." lastupdate="Fri, 30 Mar 2018 19:37:35 +0200"/>
	<group id="153" name="alt.binaries.dvd.music" description="This group contains DVDR Music." lastupdate="Sat, 07 Apr 2018 22:32:46 +0200"/>
	<group id="158" name="alt.binaries.dvd.music.classical" description="Dvd Classical music" lastupdate="Mon, 02 Apr 2018 22:19:24 +0200"/>
	<group id="28" name="alt.binaries.e-book" description="This group contains E-Books." lastupdate="Tue, 10 Apr 2018 19:30:32 +0200"/>
	<group id="52" name="alt.binaries.e-book.flood" description="This group contains E-Books." lastupdate="Mon, 09 Apr 2018 03:21:44 +0200"/>
	<group id="197" name="alt.binaries.e-book.magazines" lastupdate="Tue, 10 Apr 2018 16:20:03 +0200"/>
	<group id="41" name="alt.binaries.e-book.technical" description="This group contains E-Books." lastupdate="Tue, 10 Apr 2018 18:13:50 +0200"/>
	<group id="96" name="alt.binaries.ebook" description="This group contains Ebook's." lastupdate="Tue, 10 Apr 2018 15:34:25 +0200"/>
	<group id="82" name="alt.binaries.etc" description="This group contains a variety of items." lastupdate="Tue, 10 Apr 2018 21:23:27 +0200"/>
	<group id="201" name="alt.binaries.felodzi" lastupdate="Tue, 12 Jul 2016 10:33:11 +0200"/>
	<group id="203" name="alt.binaries.friends" lastupdate="Wed, 20 Dec 2017 08:07:49 +0200"/>
	<group id="193" name="alt.binaries.frogs" lastupdate="Tue, 10 Apr 2018 21:23:22 +0200"/>
	<group id="32" name="alt.binaries.ftn" description="This group contains a variety of Music and TV." lastupdate="Tue, 10 Apr 2018 21:23:06 +0200"/>
	<group id="34" name="alt.binaries.games" description="This group contains PC and Console Games." lastupdate="Tue, 10 Apr 2018 19:22:19 +0200"/>
	<group id="10" name="alt.binaries.games.nintendods" description="This group contains Nintendo DS Games " lastupdate="Fri, 10 Nov 2017 18:50:45 +0200"/>
	<group id="13" name="alt.binaries.games.wii" description="This group contains Nintendo WII Games, WII-Ware, and VC." lastupdate="Tue, 03 Apr 2018 09:20:58 +0200"/>
	<group id="6" name="alt.binaries.games.xbox" description="This group contains original XBOX Games." lastupdate="Tue, 27 Mar 2018 07:53:18 +0200"/>
	<group id="12" name="alt.binaries.games.xbox360" description="This group contains XBOX 360 Games and DLC." lastupdate="Mon, 09 Apr 2018 09:07:44 +0200"/>
	<group id="122" name="alt.binaries.hdtv" lastupdate="Tue, 10 Apr 2018 21:22:56 +0200"/>
	<group id="11" name="alt.binaries.hdtv.x264" description="This group contains X264 Movies and HDTV." lastupdate="Tue, 10 Apr 2018 21:22:58 +0200"/>
	<group id="89" name="alt.binaries.highspeed" description="This group contains XVID Movies. Mostly Foreign." lastupdate="Tue, 10 Apr 2018 20:37:50 +0200"/>
	<group id="18" name="alt.binaries.inner-sanctum" description="This group contains PC and Music." lastupdate="Tue, 10 Apr 2018 21:00:22 +0200"/>
	<group id="109" name="alt.binaries.ipod.videos" description="This group contains Mobile TV and Movies." lastupdate="Sat, 10 Mar 2018 23:29:38 +0200"/>
	<group id="205" name="alt.binaries.jerry" lastupdate="Tue, 10 Apr 2018 20:52:46 +0200"/>
	<group id="195" name="alt.binaries.kenpsx" lastupdate="Tue, 10 Apr 2018 21:22:31 +0200"/>
	<group id="2" name="alt.binaries.linux.iso" description="This group contains Linux distributions." lastupdate="Sat, 07 Apr 2018 04:20:26 +0200"/>
	<group id="173" name="alt.binaries.lou" lastupdate="Tue, 10 Apr 2018 20:59:57 +0200"/>
	<group id="27" name="alt.binaries.mac" description="This group contains MAC/OSX Software." lastupdate="Tue, 10 Apr 2018 19:36:40 +0200"/>
	<group id="183" name="alt.binaries.milo" lastupdate="Fri, 10 Nov 2017 18:49:48 +0200"/>
	<group id="83" name="alt.binaries.misc" description="This group contains a variety of items." lastupdate="Tue, 10 Apr 2018 21:22:10 +0200"/>
	<group id="25" name="alt.binaries.mma" description="This group contains MMA/TNA Sport TV." lastupdate="Mon, 18 Dec 2017 11:03:44 +0200"/>
	<group id="177" name="alt.binaries.mojo" lastupdate="Tue, 10 Apr 2018 17:42:06 +0200"/>
	<group id="17" name="alt.binaries.moovee" description="This group contains XVID and X264 Movies." lastupdate="Tue, 10 Apr 2018 21:22:08 +0200"/>
	<group id="132" name="alt.binaries.movies" description="This group contains an assortment of Movies." lastupdate="Tue, 10 Apr 2018 21:21:52 +0200"/>
	<group id="5" name="alt.binaries.movies.divx" description="This group contains XVID Movies" lastupdate="Tue, 10 Apr 2018 19:43:52 +0200"/>
	<group id="67" name="alt.binaries.mp3.audiobooks" description="This group contains Audio Books." lastupdate="Tue, 10 Apr 2018 03:06:24 +0200"/>
	<group id="98" name="alt.binaries.mp3.full_albums" description="This group contains a variety of Music." lastupdate="Sun, 11 Mar 2018 15:52:30 +0200"/>
	<group id="23" name="alt.binaries.mpeg.video.music" description="This group contains a variety of Music Videos." lastupdate="Sun, 17 Dec 2017 11:52:45 +0200"/>
	<group id="4" name="alt.binaries.multimedia" description="This group contains TV, Movies, and Music." lastupdate="Tue, 10 Apr 2018 21:21:40 +0200"/>
	<group id="75" name="alt.binaries.multimedia.anime" description="This group contains Anime TV and Movies." lastupdate="Mon, 09 Apr 2018 03:34:54 +0200"/>
	<group id="137" name="alt.binaries.multimedia.anime.highspeed" description="This group contains Anime Television." lastupdate="Tue, 10 Apr 2018 21:14:01 +0200"/>
	<group id="139" name="alt.binaries.multimedia.anime.repost" description="This group contains Anime Television." lastupdate="Mon, 09 Apr 2018 03:34:48 +0200"/>
	<group id="73" name="alt.binaries.multimedia.cartoons" description="This group contains Cartoon TV and Movies." lastupdate="Fri, 06 Apr 2018 00:41:15 +0200"/>
	<group id="118" name="alt.binaries.multimedia.classic-films" description="This group contains Classic TV and Movies." lastupdate="Tue, 10 Apr 2018 10:22:08 +0200"/>
	<group id="81" name="alt.binaries.multimedia.comedy.british" description="This group contains British Comedy TV and Movies." lastupdate="Sat, 07 Apr 2018 02:43:23 +0200"/>
	<group id="155" name="alt.binaries.multimedia.cooking" description="This group contains Cooking TV" lastupdate="Tue, 10 Apr 2018 16:48:14 +0200"/>
	<group id="77" name="alt.binaries.multimedia.disney" description="This group contains Disney TV and Movies." lastupdate="Fri, 10 Nov 2017 18:48:43 +0200"/>
	<group id="54" name="alt.binaries.multimedia.documentaries" description="This group contains Documentary Movies and TV." lastupdate="Fri, 06 Apr 2018 17:37:46 +0200"/>
	<group id="151" name="alt.binaries.multimedia.scifi" lastupdate="Tue, 10 Apr 2018 20:28:39 +0200"/>
	<group id="152" name="alt.binaries.multimedia.scifi-and-fantasy" lastupdate="Mon, 26 Feb 2018 19:23:13 +0200"/>
	<group id="79" name="alt.binaries.multimedia.sitcoms" description="This group contains Sitcom TV." lastupdate="Fri, 10 Nov 2017 18:48:30 +0200"/>
	<group id="74" name="alt.binaries.multimedia.sports" description="This group contains Sports TV and Movies." lastupdate="Tue, 10 Apr 2018 08:44:13 +0200"/>
	<group id="112" name="alt.binaries.multimedia.tv" description="This group contains XVID and X264 TV." lastupdate="Tue, 27 Mar 2018 08:57:31 +0200"/>
	<group id="119" name="alt.binaries.music.flac" description="This group contains a variety of lossless Music" lastupdate="Tue, 10 Apr 2018 21:20:40 +0200"/>
	<group id="110" name="alt.binaries.music.opera" description="This group contains Opera Music." lastupdate="Fri, 10 Nov 2017 18:48:14 +0200"/>
	<group id="9" name="alt.binaries.nintendo.ds" description="This group contains Nintendo DS Games" lastupdate="Fri, 08 Dec 2017 10:11:07 +0200"/>
	<group id="161" name="alt.binaries.nospam.cheerleaders" description="Movies and stuff" lastupdate="Sat, 07 Apr 2018 02:20:45 +0200"/>
	<group id="148" name="alt.binaries.paranormal" lastupdate="Tue, 10 Apr 2018 20:35:41 +0200"/>
	<group id="130" name="alt.binaries.pictures.comics.complete" description="This group contains comics." lastupdate="Sat, 07 Apr 2018 04:03:45 +0200"/>
	<group id="127" name="alt.binaries.pictures.comics.dcp" description="This group contains Comic Books." lastupdate="Mon, 19 Mar 2018 10:29:23 +0200"/>
	<group id="128" name="alt.binaries.pictures.comics.repost" description="This group contains Comic Books." lastupdate="Tue, 10 Apr 2018 21:20:15 +0200"/>
	<group id="129" name="alt.binaries.pictures.comics.reposts" description="This group contains Comic Books." lastupdate="Tue, 10 Apr 2018 19:42:15 +0200"/>
	<group id="46" name="alt.binaries.pro-wrestling" description="This group contains WWE Sport TV." lastupdate="Fri, 01 Dec 2017 16:52:58 +0200"/>
	<group id="39" name="alt.binaries.scary.exe.files" description="This group contains XVID and X264 Movies." lastupdate="Tue, 10 Apr 2018 21:20:14 +0200"/>
	<group id="8" name="alt.binaries.sony.psp" description="This group contains PSP Games." lastupdate="Fri, 06 Apr 2018 12:12:27 +0200"/>
	<group id="114" name="alt.binaries.sound.audiobooks" description="This group contains Audiobooks." lastupdate="Fri, 10 Nov 2017 18:47:37 +0200"/>
	<group id="93" name="alt.binaries.sound.mp3" description="This group contains a variety of Music." lastupdate="Mon, 26 Feb 2018 19:18:45 +0200"/>
	<group id="88" name="alt.binaries.sounds.audiobooks.repost" description="This group contains Audiobooks." lastupdate="Sat, 31 Mar 2018 03:14:15 +0200"/>
	<group id="154" name="alt.binaries.sounds.flac" description="This group contains a variety of lossless Music." lastupdate="Tue, 10 Apr 2018 19:49:39 +0200"/>
	<group id="111" name="alt.binaries.sounds.flac.jazz" description="This group contains lossless Jazz Music." lastupdate="Sat, 09 Dec 2017 04:41:24 +0200"/>
	<group id="47" name="alt.binaries.sounds.lossless" description="This group contains a variety of Lossless Music." lastupdate="Tue, 10 Apr 2018 19:03:42 +0200"/>
	<group id="76" name="alt.binaries.sounds.lossless.classical" description="This group contains lossless Classical Music." lastupdate="Mon, 09 Apr 2018 19:31:03 +0200"/>
	<group id="115" name="alt.binaries.sounds.mp3.acoustic" description="This group contains Accoustic Music." lastupdate="Thu, 14 Dec 2017 01:22:22 +0200"/>
	<group id="26" name="alt.binaries.sounds.mp3.classical" description="This group contains Classical Music." lastupdate="Sun, 08 Apr 2018 00:27:02 +0200"/>
	<group id="59" name="alt.binaries.sounds.mp3.comedy" description="This group contains Comedy Audio." lastupdate="Sat, 10 Mar 2018 22:50:00 +0200"/>
	<group id="22" name="alt.binaries.sounds.mp3.complete_cd" description="This group contains a variety of Music." lastupdate="Tue, 10 Apr 2018 16:31:08 +0200"/>
	<group id="70" name="alt.binaries.sounds.mp3.dance" description="This group contains Dance Music." lastupdate="Fri, 06 Apr 2018 10:19:54 +0200"/>
	<group id="69" name="alt.binaries.sounds.mp3.full_albums" description="This group contains a variety of Music." lastupdate="Tue, 10 Apr 2018 05:27:28 +0200"/>
	<group id="72" name="alt.binaries.sounds.mp3.heavy-metal" description="This group contains Heavy Metal Music." lastupdate="Sun, 08 Apr 2018 07:30:09 +0200"/>
	<group id="92" name="alt.binaries.sounds.mp3.musicals" description="This group contains Musicals Music." lastupdate="Thu, 05 Apr 2018 02:42:37 +0200"/>
	<group id="78" name="alt.binaries.sounds.mp3.nospam" description="This group contains a variety of Music." lastupdate="Fri, 10 Nov 2017 18:46:45 +0200"/>
	<group id="108" name="alt.binaries.sounds.mp3.opera" description="This group contains Opera Music." lastupdate="Thu, 30 Nov 2017 10:21:35 +0200"/>
	<group id="131" name="alt.binaries.sounds.mp3.rap-hiphop" description="This group contains Rap and Hip-Hop Music." lastupdate="Sat, 10 Mar 2018 22:47:22 +0200"/>
	<group id="189" name="alt.binaries.squaresoft" lastupdate="Fri, 10 Nov 2017 18:46:33 +0200"/>
	<group id="20" name="alt.binaries.teevee" description="This group contains X264 and XVID TV." lastupdate="Tue, 10 Apr 2018 20:19:30 +0200"/>
	<group id="43" name="alt.binaries.test" description="This group contains a variety of content." lastupdate="Tue, 10 Apr 2018 21:26:20 +0200"/>
	<group id="123" name="alt.binaries.town" description="This group contains XVID TV and Movies. Mostly Foreign." lastupdate="Mon, 09 Apr 2018 22:33:04 +0200"/>
	<group id="185" name="alt.binaries.triballs" lastupdate="Tue, 10 Apr 2018 21:26:14 +0200"/>
	<group id="169" name="alt.binaries.tun" lastupdate="Tue, 10 Apr 2018 20:26:24 +0200"/>
	<group id="99" name="alt.binaries.tv" description="This group contains XVID TV." lastupdate="Tue, 10 Apr 2018 21:26:05 +0200"/>
	<group id="30" name="alt.binaries.tvseries" description="This group contains X264 and XVID TV." lastupdate="Tue, 10 Apr 2018 21:26:01 +0200"/>
	<group id="175" name="alt.binaries.ucc" lastupdate="Fri, 10 Nov 2017 18:46:02 +0200"/>
	<group id="181" name="alt.binaries.ufg" lastupdate="Tue, 10 Apr 2018 17:46:02 +0200"/>
	<group id="149" name="alt.binaries.ufo.files" lastupdate="Tue, 03 Apr 2018 21:22:15 +0200"/>
	<group id="29" name="alt.binaries.warez.ibm-pc.0-day" description="This group contains PC-0Day." lastupdate="Fri, 10 Nov 2017 18:45:51 +0200"/>
	<group id="49" name="alt.binaries.warez.quebec-hackers" description="This group contains PC-0day. Some Foreign." lastupdate="Sun, 08 Apr 2018 08:35:38 +0200"/>
	<group id="19" name="alt.binaries.warez.smartphone" description="This group contains Mobile Phone Apps." lastupdate="Thu, 23 Nov 2017 17:07:09 +0200"/>
	<group id="191" name="alt.binaries.warez.win95-apps" lastupdate="Tue, 10 Apr 2018 18:16:06 +0200"/>
	<group id="136" name="alt.binaries.worms" description="I have no idea what this group contains besides a lot of U4ALL which isn't really usable." lastupdate="Tue, 10 Apr 2018 20:40:59 +0200"/>
	<group id="15" name="alt.binaries.x264" description="This group contains X264 Movies and TV." lastupdate="Tue, 10 Apr 2018 20:26:09 +0200"/>
</groups>
<genres>
	<genre id="71" categoryid="3000" name=""/>
	<genre id="21" categoryid="1000" name="Action"/>
	<genre id="27" categoryid="1000" name="Adventure"/>
	<genre id="9" categoryid="3000" name="Alternative Rock"/>
	<genre id="29" categoryid="1000" name="Arcade"/>
	<genre id="43" categoryid="3000" name="Blues"/>
	<genre id="67" categoryid="1000" name="Board Games"/>
	<genre id="45" categoryid="3000" name="Broadway &amp; Vocalists"/>
	<genre id="73" categoryid="1000" name="Casino"/>
	<genre id="65" categoryid="3000" name="Children's Music"/>
	<genre id="57" categoryid="3000" name="Christian &amp; Gospel"/>
	<genre id="51" categoryid="3000" name="Classic Rock"/>
	<genre id="11" categoryid="3000" name="Classical"/>
	<genre id="35" categoryid="3000" name="Country"/>
	<genre id="15" categoryid="3000" name="Dance &amp; Electronic"/>
	<genre id="75" categoryid="1000" name="Family"/>
	<genre id="77" categoryid="1000" name="Fighting"/>
	<genre id="61" categoryid="1000" name="Flying"/>
	<genre id="47" categoryid="3000" name="Folk"/>
	<genre id="1" categoryid="3000" name="Hard Rock &amp; Metal"/>
	<genre id="7" categoryid="3000" name="Jazz"/>
	<genre id="59" categoryid="3000" name="Latin Music"/>
	<genre id="17" categoryid="3000" name="Miscellaneous"/>
	<genre id="69" categoryid="3000" name="New Age"/>
	<genre id="13" categoryid="3000" name="Pop"/>
	<genre id="23" categoryid="1000" name="Puzzle"/>
	<genre id="49" categoryid="3000" name="R&amp;B"/>
	<genre id="39" categoryid="1000" name="Racing"/>
	<genre id="38" categoryid="1000" name="Racing"/>
	<genre id="19" categoryid="3000" name="Rap &amp; Hip-Hop"/>
	<genre id="55" categoryid="1000" name="Rhythm"/>
	<genre id="5" categoryid="3000" name="Rock"/>
	<genre id="25" categoryid="1000" name="Role-Playing"/>
	<genre id="79" categoryid="1000" name="Shooter"/>
	<genre id="53" categoryid="1000" name="Simulation"/>
	<genre id="3" categoryid="3000" name="Soundtracks"/>
	<genre id="33" categoryid="1000" name="Sports"/>
	<genre id="41" categoryid="1000" name="Strategy"/>
	<genre id="63" categoryid="1000" name="Trivia"/>
	<genre id="31" categoryid="1000" name="Unknown"/>
	<genre id="37" categoryid="3000" name="World Music"/>
</genres>
Seems to be working for me today
