Can't connect to NAS and I have tried everything in FAQ
Sonarr version (exact version): 2.0.0.4753
Mono version (if Sonarr is not running on Windows): N/A
OS: Windows 10
((Debug logs)): https://drive.google.com/open?id=0Bw_4qglq2wI6cUgzQnk0UTNxenc
Description of issue: NAS is not connecting. I have placed NZBdrone in startup folder, I changed the mapped drive to UNC (server_ip/shows) and I changed the services to different users. Please look at the screen shots I have attached with the Debug log.
Please help?
Many thanks,
Abdulla
PS: I’m a doner
Did you also stop and disable the service when you did this?
I’m not seeing anything in the logs attempting to connect to either the mapped network drive or the UNC path.
Thanks for your support.
Thanks for the swift response.
I uninstalled it and put nzbdrone in the startup folder. It reconginzed the drive.
Awesome man. Thank you so much.
Abdulla
