I’m looking for some help to solve my issue trying to get NZBGeek added as an indexer. I’ve also got this posted at NZBGeek and working through it as well. I have the latest .NET version installed 4.7.2 but still unable to get the indexer added. I have CouchPotato, SABnzbd, and SickBeard working without issue, but unable to get NZBGeek added. This is my 3rd complete reinstall of OS and all software and still can’t get the indexer installed. Any help or direction is appreciated.
Gigabyte B450 Aorus M
Ryzen 2400G
16 gig Corsair Vengeance
OCZ 150 SSD
4 TB WD HDD
550W PSU
Sonarr version 2.0.0.5252:
Windows 10 Home:
“Request Failed. POST /api/indexer/test: Input string was not in a correct format.” This is a new install and setup.
Log info:
Exception
System.FormatException: Input string was not in a correct format.
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
at System.Convert.ToInt32(String value)
at NzbDrone.Api.ClientSchema.SchemaBuilder.<>c.<GetValueConverter>b__8_8(String s) in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Api\ClientSchema\SchemaBuilder.cs:line 189
at System.Linq.Enumerable.WhereSelectArrayIterator2.MoveNext() at System.Linq.Enumerable.Any[TSource](IEnumerable
1 source)
at NzbDrone.Core.Indexers.Newznab.NewznabSettingsValidator.<>c.<.ctor>b__3_0(NewznabSettings newznab) in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\Indexers\Newznab\NewznabSettings.cs:line 42
at FluentValidation.AbstractValidator1.<>c__DisplayClass19_0.<Custom>b__0(T x) in C:\projects\FluentValidation\src\FluentValidation\AbstractValidator.cs:line 187 at FluentValidation.Internal.DelegateValidator
1.<>c__DisplayClass10_0.<.ctor>b__0(T x, ValidationContext1 ctx) in C:\projects\FluentValidation\src\FluentValidation\Internal\DelegateValidator.cs:line 58 at FluentValidation.Internal.DelegateValidator
1.Validate(ValidationContext1 context) in C:\projects\FluentValidation\src\FluentValidation\Internal\DelegateValidator.cs:line 82 at FluentValidation.Internal.DelegateValidator
1.Validate(ValidationContext context) in C:\projects\FluentValidation\src\FluentValidation\Internal\DelegateValidator.cs:line 107
at FluentValidation.AbstractValidator1.<>c__DisplayClass12_0.<Validate>b__0(IValidationRule x) in C:\projects\FluentValidation\src\FluentValidation\AbstractValidator.cs:line 114 at System.Linq.Enumerable.<SelectManyIterator>d__17
2.MoveNext()
at System.Collections.Generic.List1..ctor(IEnumerable
1 collection)
at System.Linq.Enumerable.ToList[TSource](IEnumerable1 source) at FluentValidation.AbstractValidator
1.Validate(ValidationContext1 context) in C:\projects\FluentValidation\src\FluentValidation\AbstractValidator.cs:line 114 at FluentValidation.AbstractValidator
1.Validate(T instance) in C:\projects\FluentValidation\src\FluentValidation\AbstractValidator.cs:line 95
at NzbDrone.Core.Indexers.Newznab.NewznabSettings.Validate() in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\Indexers\Newznab\NewznabSettings.cs:line 92
at NzbDrone.Api.ProviderModuleBase3.Validate(TProviderDefinition definition, Boolean includeWarnings) in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Api\ProviderModuleBase.cs:line 199 at NzbDrone.Api.Indexers.IndexerModule.Validate(IndexerDefinition definition, Boolean includeWarnings) in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Api\Indexers\IndexerModule.cs:line 34 at NzbDrone.Api.ProviderModuleBase
3.Test(TProviderResource providerResource) in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Api\ProviderModuleBase.cs:line 178
at NzbDrone.Api.ProviderModuleBase3.<.ctor>b__1_1(Object x) in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Api\ProviderModuleBase.cs:line 28 at CallSite.Target(Closure , CallSite , Func
2 , Object )
at Nancy.Routing.Route.<>c__DisplayClass4.<Wrap>b__3(Object parameters, CancellationToken context)
