Sonarr version 3.0.9.1549:
Windows 10:
The following appears in my activity queue.
Mayfair.Witches.S01E01.1080p.WEB.H264-GGEZ
- Found matching series via grab history, but release was matched to series by ID. Automatic import is not possible.
Which is fine except that as the file does not appear in any other place it does not seem to be possible to manually import it either. Obviously I can just use Windows to copy the file over but if there’s any way to avoid a repeat of this for every episode of the series I’d be grateful to hear it along with an explanation of how the situation arises in the first place.
Edit: In attempting to transfer the file I’ve discovered that no folder was created in the process of adding the show. I also added another show this morning and that does not have a folder either. Any ideas?
