Can you help me troubleshoot? Suddenly not working
Please understand, I’m not a linux guru… so I’m probably missing obvious steps to someone that knows it better than I.
I have Ubuntu (upgraded a few months ago from 12.04LTS to whatever the lastest LTS is… 14.04 I think?).
NZBdrone was working perfectly for a long time.
Yesterday, I installed Ajenti on my server. I’m not sure if that is related or not. This morning, NZBDrone isn’t working, at least not on the port I always used.
When I run the command “sudo start nzbdrone” It seems to work fine, but I just get “This webpage is not available” in chrome.
I’m not sure how to confirm what port it is running on. I’ve always use 8081 (if that’s not standard, then I defined that back when I first set it up).
Help set me on the right path! Thanks.
Nevermind. I fixed it myself. I don’t really need Ajenti :smile:
I reversed the steps I took to install Ajenti and, after reboot, it works again. In between there was also an update to nzbdrone. So I’m not sure if it was Ajenti removal or the nzbdrone update that cured my ails, but I also don’t really care. So feel free to ignore this.
