I have no idea what happened here, but I can not open Sonarr in any of my browsers using http://localhost:8989 anymore. Have tried http, https and my local IP address. Despite that Sonarr is sending my snatches to NZBGet. Only thing in my log that is indicative is - " 13/03/15 22:09:45,078 com.apple.xpc.launchd[1]: (com.osx.sonarr.tv.39508[693]) Service exited with abnormal code: 1 "
Can´t figure it out. Anyone ?
Edit: I created a guest account on my Mac and tried Sonarr there. It worked, but that´s not a satisfactory solution.
Any change if you restart Sonarr?
Anything in Sonarr’s logs? (Log files are in: /Users/<username>/.config/NzbDrone/logs
No success when restarting Sonarr or rebooting my Mac. However, I was able to get Sonarr running after creating a another user account, but that´s not a good solution. I had no problem in the last few weeks running it from my admin account. I am willing to re-install the app if you think it´s worth a try… .
Update: Reinstalled. All is well now
15-3-13 22:46:16.1|Info|Bootstrap|Starting NzbDrone - /Applications/Sonarr.app/Contents/MacOS/nzbdrone.exe - Version 2.0.0.2850
15-3-13 22:46:16.7|Debug|ProcessProvider|Found 0 processes with the name: NzbDrone.Console
15-3-13 22:46:17.1|Debug|ProcessProvider|Found 0 processes with the name: NzbDrone
15-3-13 22:46:17.1|Info|MigrationLogger|*** Migrating data source=/Users/sentinel/.config/NzbDrone/nzbdrone.db;cache size=-10485760;datetimekind=Utc;journal mode=Truncate;pooling=True;version=3 ***
15-3-13 22:46:17.3|Debug|MigrationLogger|Took: 00:00:00.1241503
15-3-13 22:46:17.3|Info|MigrationLogger|*** Migrating data source=/Users/sentinel/.config/NzbDrone/logs.db;cache size=-10485760;datetimekind=Utc;journal mode=Truncate;pooling=True;version=3 ***
15-3-13 22:46:17.3|Fatal|ConsoleApp|EPIC FAIL!
System.Data.SQLite.SQLiteException: database disk image is malformed
at System.Data.SQLite.SQLite3.Prepare (System.Data.SQLite.SQLiteConnection cnn, System.String strSql, System.Data.SQLite.SQLiteStatement previous, UInt32 timeoutMS, System.String& strRemain) [0x00000] in :0
at System.Data.SQLite.SQLiteCommand.BuildNextCommand () [0x00000] in
Looks like it was caused by DB corruption. Deleting /Users/sentinel/.config/NzbDrone/logs.db
also would have fixed it up.
Thank you very much for following me up. I´ll remember to delete logs.db should the problem arise again. Glad Sonarr is functional again - wonderful program
