Calendar not updated correctly when an episode is deleted
Mono version (if Sonarr is not running on Windows): n/a
OS: Windows 10
Hi all,
I have the setting “Ignore Deleted Episodes” turned on. It is un-monitoring an episode when it is deleted.
When I click on en episode in the calendar, and delete the file from the pop-up window, the episode is not monitored anymore (as it should be), but it’s still shown in the calendar.
The only change in the calendar is a color change from green (Downloaded) to red (missing).
When moving to next month calendar, and back to the current one, the calendar is updated, and the episode is not shown anymore.
I would expect it to be removed immediately when it is deleted, and not having just a color change.
Is this a bug in the app?
Can one of the developers address the issue.
Thank you very much.
