Calendar color for Downloaded but under Cutoff
Hi!
Good job on the last updates, lots of things added.
I was wondering if it would be possible to add a different color coding for an episode that has been downloaded but has not met the cutoff yet. This way they are easier to spot.
Many thanks
Fred
Just my opinion here, but if it’s going to be done I think it should be a subtle difference, like a slightly darker green for cutoff met, the existing green for not met.
Agreed! Darker green for cutoff met is what I had in mind.
Have to be careful with colours, as current day downloads (green) is “brighter” than previous days downloaded (very slightly).
Another concern with colours is people with deficiencies.
Likely if this is implemented we’d look at a darker green when the cutoff hasn’t yet been met, this would retain the brighter colour for it having met the cutoff.
Added to Github for comments from the other devs: https://github.com/Sonarr/Sonarr/issues/592
